Old 07 Apr 2004, 02:32 pm
redrum redrum is offline
gary--the paint kits are available on ebay quite often. the kit comes with aerosol cleaner for cleaning and degreasing, the paint, catalyst and a small brush to apply the paint. when i painted my calipers, i just lifted the car totally off the ground, removed the wheels, cleaned and brushed any loose dirt grease and rust scale and painted away. there is plenty of paint to do the calipers. might be enough to paint the hats on the rotors. certainly enough to hilight the raised aluminum on your turbo manifold. i though of the last option about 8 hours after the paint had hardened in the can into a brick. doh! you have a number of hours to work with the paint, enough time for 2 coats. the next time i will just mix 1/2 the paint and save the other 1/2 for paint projects.
redrum
03 GT
