[center]
Hey guys! Well, Turbo, I have to tell ya', my kits are not that cheap as I use transformers that cost more than those SG's you have! Now, that is not to say that SG doesn't have a good product because they do. It's just that I don't use the types of transformers that barely get the job done...I can supply you with a transformer which will allow you to add more tubes later on, say under your seats, or I can supply you with a smaller unit that will EASILY power your under dash accents. I use a 6000 volt 30mA unit for add on possibility, and a 2000 or 4500 volt 20mA unit for two tube sets. I sell the lower voltage kit for $65.00 plus shipping. The 6000 volt deal will run $100.00. Yes I know this is high for accent neon tubing, but I make my accent tube kits the same as my underbody kits. I use GTO wire instead of small wire, and I use top quality accessories. By doing this I know what the customer is getting and makes me feel confident of the package. The low-priced packages out there are also low cost to the seller, and I do not believe in their reliability. The reason for the high price of the 6000 volt kit is my transformer cost, which is almost half of that price! Even being a neon company, I do not get a good deal, but I stay with them because they are the best...bar none! So you see, you may want to try and get your set up figured out a bit more before spending any extra money...Below is an interior shot of the Suburban above running a 6000 volt setup...He also has tubes under his seat in the back off of this unit.
Thanks again guys for your warm welcomes and I hope I can continue to shed some light on...uhhh...light![8D]
