Old 10 Apr 2004, 11:22 am
Todd TCE Todd TCE is offline
While having taken a 'personal turn', too which I apologize for my screaming at times, there is some valuable info in there for you.
The two main issues you have to deal with have not chnaged:
1. Spindle mount of caliper brackets (discussed)
2. Wheel clearance (also discussed)
Both of these remailn your primary hurdles depending upon what type of parts are used on the particular kit you choose.
I don't represent ST and cannnot make claims to what they fit and do not, however someone mentioned the use of twin piston calipers on it thus I'll go out on a limb a bit and suggest that they may be a more narrow design than the more common four pot.
The WW kit also uses a more compact design (the Dynalite) on the .81 rotor to gain clearance.
Better? At this level I'd favor the ST kit (despite selling the other) for caliper quality, however the WW kit has beneifts in cost, probably some packaging room and a much wider assortment of pads to work with.
Now for the plug; if neither of these are up to the level to which you want to operate, and we in fact confirm the PT kits can use the same bracket as the Turbo PT....then the TCE kit for the SRT4 in either .81 or in 1.10 rotor width will be the choice over the two above. It WILL however compromise wheel clearance more then either of these above, probably in .81 form also given the larger body Forged Superlite caliper over the WW's Dynalite. At least worthy of consideration if serious braking or open track days are in your fututre. Price is bumped up also to about $1100 and options a plenty so budget minded folks may wish to pass. Replacement pads, rotors and such are also less than some of the others.
For feedback you may want to check out: <a couple of references>
NLOC.com (see racing forum)
Focaljet.com (see racing forum)
SSforums.com (see brakes forum)
Should you wish a pic of this on an SRT4 you can email me as I took them yesterday. Or if someone has a web link to send it to and post it here all the better.
Hoping this answers some or most of your questions.
