Not to be critical here,,,, BUT,,,, That is not real pretty. I believe that the HP / Torq curves should cross at around 5400 RPM. Not totally sure if it's 5200 or 5400, but it is a CONSTANT. I've never seen any that didn't. I think you've got some poor results there. Possibly some bad sensors,,, just looking at the choppyness on all of the curves. Coulda been a loose connection to the puter. Were they all done in 4th gear ???
To see the torque drop off that much is a sure sign that something is not right. All of these cars are showing higher torque numbers that horsepower numbers, but that differential is significant.
03 GT PT, Inferno Red w/factory flames, AutoStick, Stage 1, Mopar BOV, BTG duals, Airaid, 5 HP fuzzy dice
