Old 12 Apr 2004, 10:42 pm
PTGT_Boy PTGT_Boy is offline
The 1/4 mile time seems awfully too good to be true for a stock 04 GT (Auto). Those results would make me happy that I didn't buy an SRT-4
I believe Ian has done some runs on a track with a stock 04 GT (Auto). In addition, I believe he's in California, summary results:
Best 1/4 mile result on Auto-stick: 15.37 sec
Best 1/4 mile result on Drive: 15.7 sec
Quoted from: http://www.ptcruiserlinks.com/forum/...Cversus%2Cauto
This issue reminds me of the "Trans-am, Camaro Issue" which one is better???
I have not driven a 5-speed PT Turbo. All I can say is for the automatic. Check my "PT Turbo Strip Performance" Post in the PT Turbo forum.
I tested the car in "D" mode and "Auto Stick" mode and I had to retract on my statement that the "Manual mode doesn’t work for drag".
My passes in "D" mode were of 15.75 at 85.4 MPH
My passes in "Auto Stick" mode were 15.37 at 94.5 MPH
There is a marked difference in the two and the reason is "Overdrive" In "D" mode the car shifted to fourth when the tach read 4000 RPM and I was still in the 1/4 mile run.
In "auto Stick" mode all the shifts where done at redline. You don’t even have to worry about shifting; the computer will do it for you in all first three gears.
All this tests were done with the car Bone Stock.
The only way we can put this issue to rest is by taking a 5-Speed car to the track and race it Bone Stock and compare the numbers.
My two cents.
Ian
