I read quite some posts in regards of removing silencers. It seems to me that if you remove the silencers w/o disconnecting the battery, you should get a slight increase in times. If you remove the silencers and disconnet the battery, you won't get an increase in times as the PCM will adjust to modification. 3BarBoost has stated quite a few times that the PCM will adjust to the silencers being removed.
To really get the benefits of removing the silencers or new intake, you will need a manual boost controller.
Disclaimer: This is just my opinion on the info flowing through this site. I have not modified my intake or removed the silencers nor have a manual boost controller.
