The front doors can hold 6.5" speaker. The Front dash has 3.5" speakers, but it is a tweeter in there. I replace my doors and dash with a 6.5" comp. set which is 6.5" Midbass woofer and a 1" dome tweeter. I cut a piece of wood to fit the area so I can mount my tweeter. I had to cut nothing all looks factory. You do have to buy a mounting plate or make one for the doors. It is an over-sized 6.5" speaker even a 7" will fit.
For the rear it is a 5x7. There is now conversion unless you feel like making something. I am using 5x7 coax Alpine.
The stock radio does not put out much power maybe 7 to 8 watts per ch. I changed my radio before I changed the speakers and it made a huge difference right away. You don't need an amp unless you are going to hook up a sub and have a major system. I suggest get a good Alpine, Pioneer, Kenwood, or even Sony Radio and replacement speakers and you should OK unless you are looking for something bigger. YOu can always ad to this later also.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
