Thread: Guys need help
Old 15 Apr 2004, 05:44 pm
PTGT Redman PTGT Redman is offline
Yes, you suck all sorts of bad things into your intake and into the combustion chambers which is not good.
If you like the noise, get a cold air filter like an AirRaid or a K&N.
That helps low end throttle response, pep the car up a bit, esp if its a non-turbo. If it's a turbo, your better off with the box and a drop in filter unless you go ram air.
You got a pic of the thing that fell below the glove box?
Homepage:
