You can do a catback as long as you don't replace the converter. It bolts right on.
Dunno, what emissions are like in the UAE, however.
K&N are CARB certified here, but like I said, don't know how that applies to emissions regulations in UAE.
The airfilter is only higherflow, computer controls everything, and will eventually recalibrate it's self to bring all specs into predetermined parameters. This car has no mass airflow sensor, it uses a different system, which is much harder to "play with".
All I know is that low end throttle response is better with a aftermarket filter.
Homepage:
