Old 16 Mar 2005, 09:18 pm
MARKS-GT MARKS-GT is offline
Default $5 BUCK BOOST CONTROLLER!
IF YOU WANT TO RAISE THE BOOST ON YOUR CAR FOR CHEAP, GET A BRASS BARBED "T" TAP THE PERPENDICULAR END AND PUT A SCREW IN IT. DRILL A HOLE THROUGH THE CENTER OF THE SCREW START AT AROUND .020 SIZE. PUT THE T IN LINE WITH THE WASTEGATE HOSE. THE HOLE IN THE SCREW WILL LEAK AIR, CHEATING THE WASTEGATE TO GENERATE HIGHER BOOST. IF YOU WANT MORE BOOST WORK YOUR WAY UP ON THE HOLE SIZE. I WOULD RECOMMEND USING A BOOST GAUGE. WHAT I USED TO DO IS HAVE SEVERAL SCREWS WITH DIFFERENT SIZE HOLES IN THEM AND SWAP EM FOR MORE POWER.
IM NOT SAYING THIS IS BETTER THAN A BOOST CONTROLLER BUT FOR AROUND FIVE DOLLARS YOU CAN UP YOUR BOOST REALLY EASY.
