quote:Originally posted by quicksilverdon
Don't think auto vs stick matters, but are you going to replace the cat converter, too? If not, going to 3" will mean a bottleneck at the converter. The stock size is either 2.25" or 2.5" (I forget). I don't think 3" will hurt, just question whether it'll help.
I assume you're doing a header when to add turbo.
Hey Don,
I want to get a new exhaust system, just a good one until I get a turbo installed. One that wouldn't need to get upgraded because of that. What exhaust system would be best until then, and what would I need to change out after turbo is installed? You mentioned a header change, and cat converter (if going 3"). If I get a 2 1/4 exhaust system and want to change to a 3" system what needs to be changed there for the exhaust?
Thanks!
Don
