Ours has the molded center. Molded pieces need different installation.
Dry fit to make sure how you want it.
After you've primered the console and pulled off the red plastic, lightly spray the 3M tape with rubbing alcohol. This will make it a little slippery and not stuck on first contact. Keep holding and working until alcohol evaporates.
If your kit has a piece you don't want, practice with it first on an old piece of plastic (coke bottle?) using the alcohol.
