Old 22 Apr 2003, 11:40 am
Krieger Krieger is offline
Default VAC/BOOST Guage Data Log
One stop shopping for what readings to expect with a combo Vac/Boost guage in your PT Cruiser GT.
Upper and lower airbox silencer delete and K&N drop in filter results:
Idle cold in park: 12-14 Hg
Idle warm in park: 18 Hg
Idle in drive: 12-14 Hg
Coasting in D around 35mph: 20 Hg
Coasting in D around 65mph: 24 - 28 Hg
quick gradual 60-80% throttle: 5-8 Psi dropping rapidly
Mashed from a stop: 14 psi through 1st gear dropping down to 2 or 3 psi during shift and going back to 10 dropping fast to 8psi or lower depending on how the computer thinks it feels (ie inconsistent).
Hallman ES manual boost controller installed and conservatively set:
Same previous idle readings.
Driving around town 25-45mph steady foot: 10-14 Hg (good mpg here)
Slight need to accelerate when passing 25-45mph gradually adding approx 30% more throttle: INSTANT 5-7 PSI (pshhhhhheeeee)
Getting on freeway from a stop(mash pedal): INSTANT 14 PSI with screechin tires then slowly drops to 12 and stays until I let off throttle at 65MPH.
Cruising on freeway 65MPH flat area(steady foot): 10-12Hg
Cruising on freeway 65MPH slight incline(throttle as needed): 4-8Hg
Passing on Freeway from 60MPH no downshift gradually adding approx 30%-40% throttle: hits 10-12PSI quick
Passing on Freeway from 65MPH w/downshift and WOT: INSTANT 14PSI just before downshift then drops to 8PSI and climbs right back to ~12PSI
2003 PTCruiser GT
Mods:!Airbox silencers
K&N Filter(2153)
Autometer Pod - Boost/Vac and Volts
Hallman ES Boost Controller running 12PSI steady 14PSI peak
