quote:Originally posted by wyzard
Hi all.. Getting some gauges for my Pillar Pod and was wondering which would be easier to hook up... the Oil Pressure or Voltage meter?
Thanks.
behind the drivers side A-pillar there are a few wires you can use if you are using a pillar pod gauge. I THINK you can tap into the ORANGE wire for power. It will dim with the dash lights. Check with others to confirm this. Good Luck![?]
