Thread: exhaust problem
Old 25 Apr 2004, 08:27 am
ElectricBlueGT ElectricBlueGT is offline
paully,
This appears to be a pretty common problem when installing an aftermarket exhaust on a lowered PT. More than likely, the exhaust is hitting the rear axle whenever you hit a bump. Some people have been able to eliminate or significantly reduce the exhaust hitting the axle by going back and readjusting the exhaust to gain some clearance.
By the way, I had a similar type noise when I installed my front and rear swaybars on my stock height PT GT. I found out that the endlinks were not fully snug. Sounded like the exhaust was hitting the undercarriage. Once tightened, no more sounds.
Scott
\"If you choose not to decide, you still have made a choice.\"
