So much problems before inspection
almost due for inspection and the 01 PT got so much problems that need to have the shop fix. it's around 70k now I always drive it in the citys rough roads everyday so all this car quality weakness surfaces in this car. I hope you guys can help out letting me know what seems to cause these. THANKS
1)The AC problem I fixed is back the compressor is clicking again on and off. I'm sure it's a major leak since I fill 2 cans of freon in last week. (I'm sure the mechanic guy remove some AC lines when working on the clutch and loosen something.
2)The steering line is very wet you can see this line just looking under the front of the car. May need replacement
3)Front and rear suspension even with new bushing is making alot of metal to metal or sqeeking noise.(Tink tink tink tink!!......klnick! or this one.........EK EK EK EK from the back(what a weak suspension)
4)Around 70K now should I request a timing belt replacement?
5)this ones big..........It seems like a dragging/roaring sound coming from the back of the car occationally while it moving. Sometimes when I make standing reverse this same roaring noise from the rear. The only think that can get rid of the noise is that by pulling the hand brake.
I had it with this no matter how much $ it would cost I'll have to fix all these problems. I like the car but honestly if I can sell it I would. Yes its a manual [|)]
