I've had my AC sut down about three or four times.
I would turn off and on the car, it would work again.
The AC clutch is controlled by the PCM (go figure) It would command it to shut down if you are under heavy acceleration and turn back on when you would let go of the gas. This is the normal operation.
Since I installed S-1 I have found that the PCM would shut down the AC clutch and not turn it back on if you would floor it and let go real quick (I guess, Program Bugs).
once I noticed this, now I only floor it when I am sure I can go the distance[?]
Ian
