Took the battery in to check it out and it was fine. I think it is the switch when you push the clutch in to start it. When the car was cold I rocked it back and forth with it in first gear and then it started right up. It started the next six times in a row. I took it for a spin and it ran great. Got home, turned it off and tried to start it again and no start. Even rocking it in first did no good. If it is going to start it seems to do so when the engine is cold. So I've taken off Adam's UCP and put the factory one back on so I can take it into the dealer Monday. Hopefully it will start in the morning so I can take it in.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
