Old 05 May 2004, 04:35 pm
CREWZIN CREWZIN is offline
Snakepitt1,
The 2 links that KingKole gave you should cover what you need "if" you can log into Imagestation for the first link. If not, the second link should do the trick. Two hints that I have to share are: (1)after you take out/loosen the 5 small upper manifold bolts, my cruiser (2001) had a wire "U" clip that attached to the 2nd or 3rd bolt that went 3/4 way round the upper radiator hose to keep it straight. Don't just pull all the way up on the upper manifold without reaching around and getting that "U" clip from the radiator hose. (2) after the new plugs and wires are in, the first thing you want to do is try and get the EGR bolts (2 of them) back into the holes before you actually put anything else back together. These two bolts are the most annoying things on the whole job to get back in. If you can just start the bolts in the threads that will be enough to continue putting the rest back together.
