Old 06 May 2004, 08:51 am
CREWZIN CREWZIN is offline
Wyzard,
If there's only the one single ply tissue paper, then the sticky side of the graphic has to be on the paper itself and you have to peel the graphic off and carefully place it where you want it. You can put a very thin layer of soapy water on the area where the graphic is going to be, then place the graphic down and move it around a little to get it exactly where you want it, and squeegee the excess water out with a plastic straight edge.
If the graphic was between two layers of paper, one layer is pulled off to reveal the sticky side and the graphic is layed down where you want it and pressed down with a plastic straight edge to get any bubbles out. The soapy water can work here also.
