The items you mentioned above will NOT yield up to a 30 HP increase. More realisticly ~10-12 HP.
If your SC or turbo is installed properly, and you maintain it correctly, you should not experience reliability problems.
Ant
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
