REAR DISC BRAKE UPGRADE COMPLETED
Hi All I got the PT back yesterday and drove it around for a bit to make sure brakes were fine and they are great. I was told that the hardest of the job was installing the E-Brake cables cause the seats, the center console and some of the carpet had to be removed. The E-Brake cables for the Disc Brakes are longer. No Proprtioning Valve or Master Cylinders were needed and I saved over $2000 having it done the way it was done. If anyone want to try doing it, get the Rear Axle with as much stuff on it for as cheap as you can and do it your self.
