Old 12 May 2004, 01:57 am
brngrhd brngrhd is offline
the quicklearn should be done when installing the controller the tech would just hook up the drb3 hit quicklearn the trans will shift through the gears snd learn cvi's. cvi's are clutch volume index it tells the controller how much fluid is needed to apply the clutch. when he is done go beat it all you want. the quicklearn does what it says the trans would learn the cvi's by shifting but you have to drive nice, this just tells the controller where things are at.
\'03 pt gt s1 mopar bov auto patriot blue
1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat
http://cpatrucks.org/members/endres.html
