Old 14 May 2004, 05:14 pm
Kirby Kirby is offline
There could be a fly in this glass of water.
New OBD II testing might need to have ALL of the sensors working, I know that one of the reasons that Stage I will probably not ever be C.A.R.B approved is that it turns off some of the sensors to achieve it's magic. It's a shame too because everyone that has installed the Stage I kit has had passing smog numbers.
If DEQ finds you have modified your vehicle they "could" fine you, most probably they will make you remove the Stage I PCM so you can pass their test.[8)]
