Thread: Side 'SPEARS'?
Old 14 May 2004, 11:20 pm
Jimbo Jimbo is offline
This should help
Tools
2 - Wooden Flat Paint Stir Sticks (The kind you get with a gallon of paint.)
1 - BrakleenĀ® Solvent, or some other kind of solvent to clean off glue residue. This product is non-flammable, and dries very quickly.)
Clean rags or shop cloths
OEM Body Molding
Removal Procedure
1. I started off by using a file to round off the end of the wooden stir stick. This made it easier to insert it between the OEM body molding and the car door. Then, by holding onto the body molding and pulling with an outward motion, I was able to slide the stir stick in between the molding and the door, basically cutting the foam adhesion tape that was holding the OEM molding onto the door.
2. Once I pushed the stir stick about halfway down the door, I was able to apply steady pressure, while pulling outward on the molding, and removing it from the door.
3. There was a fairly large amount of foam backed tape still remaining on the car door. I then used the stir stick with a slight "jabbing" motion at an angle to the tape to remove the foam from the adhesive that remained on the door. The foam backing had a tendency to just roll up in a ball as I pushed it along.
4. Using a rag and the BrakleenĀ® solvent, I removed all of the remaining glue adhesive from the paint. When I was finished, I could not see any marks in the paint, or discoloring from either the wooden stir stick or the solvent. This is the most time consuming part of the job. Your ability to thoroughly prepare the surface will have a significant impact on how well the new chrome door spears adhere to the car.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
