Old 16 May 2004, 10:14 am
macster macster is offline
Send a message via AIM to macster
quote:Originally posted by Kirby
There could be a fly in this glass of water.
New OBD II testing might need to have ALL of the sensors working, I know that one of the reasons that Stage I will probably not ever be C.A.R.B approved is that it turns off some of the sensors to achieve it's magic. It's a shame too because everyone that has installed the Stage I kit has had passing smog numbers.
If DEQ finds you have modified your vehicle they "could" fine you, most probably they will make you remove the Stage I PCM so you can pass their test.[8)]
Kirby
"If" is the key. All of our mods need to be stealth like in their implentation. At the most if there are no visual signs, then its just a "sensor failure," problem. If that happens replacing the PCM should take only 15 min at best. But I'm in agreement with you on this, I guess we can "look" forward to the challenge.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
