Window problems
FYI....
Opened my door the other day and my window didn't drop. Neither window on the driver's side would work. Of course, at the dealership the next day, it worked fine! However, the DC rep was there and there is a Tech Bulletin for window and top problems. Apparently, the window controls also tie into the top control. There was a problem with some of the early PT converts and the computer mechanism needs to be "flashed" to correct the problem. If it continues to be a problem, they will replace the mechanism, but the flashing needs to be tried first. Hope this helps someone else!
