Old 25 May 2004, 02:36 pm
Gear_Head Gear_Head is offline
King, is there a remote on wire on the amp? look at the documentation for the amp and see if it is an autosensing amp. Those delay the turn on until after the head unit is initialized. Thus turning the amp on AFTER the head unit has stablized. The delay is not very long, but enough. If it is not autosensing, then it may require a remote on wire that basically performs the same function. On initialization of the head unit, the amp is signaled thru this wire and amp turn on is delayed bypassing the turn on thump. There may be an issue with installing the amp physically closer to the engine compartment than before. You might try moving it back to the trunk, wired like it was before to test that. I know it os a PITA to do that, but that will tell you if that is indeed part of the issue. I have had some amps that are extremely sensitive to the type of Radio Frequency interference that an alternator emits. It could be that the difference in physical space between the amp and the alternator is enough with the amp installad in the trunk area to eliminate picking up the RFI from the alternator.
It could also be that the RFI is fooling the autosensing circuit in the amp (if it is autosensing) into sensing the RFI as audio signal, thus negating the power on delay causing the thump as well as the alternator whine you,re hearing.
You might try this before you attempt to install filters. If the RFI is being sensed by the amps position to the alternator rather than having it introduced into the amp thru the wiring the filter may not help. That is not to say that they cannot help, bit it is best to Identify how the noise is being introduced into the amplifier.
If you want to talk about this, give me a call. Send me an e-mail for me to reply to and I'll send you my phone#. Send the E-Mail to my work address: gillla@techservintl.com
