Old 29 May 2004, 11:02 am
CREWZIN CREWZIN is offline
Yes, there's body color under the spears. There's a couple ways of taking off the spears. Heat (hair dryer?) helps a lot but it can be done without it. They are glued on, so heat softens up the glue. You can pry them off using a blunt (wooded) instrument or a fishing line used to cut the glue as you "saw" around the back and pull the spear off. Whatever you use...take your time, be careful. There will be glue residue left when your done and numerous things you can use to get that off. I use "Goo Gone" from the local hardware store.
