I know there is a problem if the dealer flashes a pcm, they can forget to do something that leaves the speedo inop. I guess there could be an issue where the s1 pcm my not have been programmed right. Did you send in the odometer statement, or did you pick this up used? When they replaced my high rpm miss pcm (TSB) the first thng I checked was speedo operation.
Tom
