Old 31 May 2004, 02:38 pm
flashbk2 flashbk2 is offline
My thoughts ...if it shows that high on factory gauge you've over-heated no ifs or buts . Probably not bad enough to harm if there's no steam or coolant boil-over. I base my thoughts on running a mechanical gauge on mine in conjunction with the factory . My car in heavy traffic can see 210-215 degrees on mech gauge while factory hasn't budged from mid. Once under motion and air is flowing better and fans come on I'm back to less than 200. Like ptgtcb says it probably was the fan not coming on when it should. I had same problem with my old '01 and I self-isolated it corroded fan relay contacts using the same mech aftermarket set-up .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
