01 Jun 2004, 12:24 pm
quote:Originally posted by GGJaguar
Well, my '04 5-speed GT (2500 miles on the clock, 12/03 build date, K&N drop-in is the only engine mod) will not start on the first try. I turn the key and the starter just spins the motor as long as I hold the key in the start position. Then I let it stop, try again and it starts right up. I don't touch the accelerator and I'm sure that I have the clutch pedal fully depressed. I also let the system power up until all the self-checks have completed before turning the engine over.
Oh, and the hard starting only occurs first thing in the morning after the car has been sitting all night. It doesn't happen when I leave work after the car has been sitting for 8 or 9 hours.
Anyone else having this problem?
Thanks!
GG
Like many fuel injected cars, it may take a few seconds to build the fuel pressure when you first turn the key before it is sufficient to start. Try turing the key to the "on" position for a few seconds before you crank it. If you open the door and listen you should hear the fuel pump running up to pressure and hear it stop. Then try to start it. If you still experience the same issue you may have some other problem
