quote:Originally posted by Cal Cruzer
Like many fuel injected cars, it may take a few seconds to build the fuel pressure when you first turn the key before it is sufficient to start. Try turing the key to the "on" position for a few seconds before you crank it. If you open the door and listen you should hear the fuel pump running up to pressure and hear it stop. Then try to start it. If you still experience the same issue you may have some other problem
Yup, that's what I've been doing. I listen to the fuel pump pressurize and watch all the warning lights go through their self-checks before attempting to start the car.
GG
