Old 19 Jun 2005, 03:38 pm
gooberff gooberff is offline
Default stage 1 install problem
I began installing stage 1 today and have a problem. After removing the PCM and the mounting bracket from the pcm, i attempted to install the bracket on the new pcm. the screws would not start and on closer inspection i discovered the new pcm was not tapped to receive the screws. Has anyone else had this problem? i will call T Thrift tommorrow at haynes to see if they can help me with this problem. For now i am dead in the water.
Can i install the injectors and run them with the stock pcm without any damage?
