Old 03 Jun 2004, 10:16 am
340x 340x is offline
I can do the same thing on the lettering in any size and format that you would like. The way that it is done is your lettering is cut out of a vinyl of your choice. It doesn't have to be lettering, it can be shapes also. After your shape is made a special material is then applied to the shape which gives it a 3D effect. This is a liquid plastic material that is uv stable so that it will not yellow. Height is usually 1/16-1/8 tall. It varies with the complexity of the shape. The thinner the lines usually the lower the height. Something like "Crewzin Edition" would typically run $30 in any color you wanted. Reflective, gold and chrome can be done also.
