Thread: stage 1 blunder
Old 04 Jun 2004, 12:53 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by JohnM
Sparky,
Please let us know how your impressions of S1 when you get the correct unit going. Thanks.
Those symptoms were the same as mine when I had the PCM replaced. The only problem was that they forgot to flash the pinion gear ratio in the PCM so if anyone else has simialar problem, check that before suspecting the a bad part. It was a much easier fix.
