That's 86,992 miles. Just be aware that at 100,000 miles there's a major servicing due, that if you can't do it yourself, the dealers in the U.S. charge somewhere around $1200 (U.S.) for parts and labor. What I'm talking about is the timing belt, water pump and tensioner.
Are there service records with the car? The transaxle is the only other (could be expensive) part that if it hasn't been serviced (flushed) by now, you could run into problems. There are other parts, power steering pump, front suspension including wheel bearings, and the multi-function stalk on the steering column (which operates the lights and fogs) that seem to be hit or miss. some owners have to replace them, others go for a longer time with no problems. Just remember that everything wears out eventually. If you can afford some sort of warranty, it might be a good investment if you don't know the cars history. CARFAX (if you have that in Canada) doesn't tell you everything. |
Thanks very much! All extremely helpful information.
I guess I'm curious now to find out if that timing belt typically fails much before the 100,000 miles - or if the manufacturer's recommended service interval has proven pretty accurate. For me, if I can "probably" get another 12,000 miles out of it before dumping in the next $1200, then it's probably economical as a car purchase right now. Personally I'm mostly attracted by the PT styling - as "$5,000 used cars" go, it's pretty much the most interesting car out there that has enough room in the back to hold my guitars and stuff. If I didn't have to load it up (and drive on the highway frequently) I'd be leaning towards one of those little "Smart" cars instead. I'm still waiting to hear back from the owner on service records. All the blue book info I could find online seems to indicate that around $4500 is the going rate for 'excellent' condition. (The car in question is a "touring" model, with automatic transmission.) Whether or not it's as excellent as the pics indicate remains to be seen... ![]() |
The Owners Manual actually calls for the timing belt change at 120,000 miles. We play it safe saying to change it at 100. Some have gone further than the 100,000 but when we hear from them, it's usually because it broke out in the road and they were stranded. Some even had the belt go before 100 but it's rare. Personally, I'd say your 90% safe till 100-110,000.
Some good info: the engine is a non-interference type. The vales can't hit the pistons for major internal damage if the belt breaks but the opposing/spinning vales can hit each other if you happen to be at medium/high speed when the belt goes south. A lot of times, as we see on the forum, the belt goes right after the car stops for a light or other stop and when you try and go again, it doesn't move, the engine light comes on and a fault code of P0340 pops up. |
The Touring in '04 was pretty stripped - the Limited Edition has more features.
A manual transmission is better on gas, eliminates the tranny worry, and is peppier. Should be no lack of PT cruisers in your price range.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
As with 99.9% of what CREWZIN posts!
What tha man said!^^^^^ ![]() ![]() The manuals are not without their clutch and cable problems. ![]() ![]()
![]() ![]() ![]() ![]() 03 Dream stock___________________________ 04 Touring turbo lite stock_________ 02 Touring stock_____________________ The "Three Amigos" __________________________________________________ __________________________________________________ ___________Performance, Body and Service, OEM This Is my project page. http://www.ptcruiserlinks.com/forum/...oject-1-a.html This is a great read from one of our own! Badglas badglas.blogspot.com Last edited by Busted_PT; 07 Feb 2013 at 08:57 pm. |
As a matter of fact, I am back in BC
![]() And I've decided I don't like the look of the 2nd Gen (2006+) PT as much as the first Gen... that front bumper kind of spoils it for me on the new ones (the way the front fascia fills in where the grill is supposed to be). Which is too bad as there are lots of 2006s floating around here... (well, in a 500km radius of here, anyway). Still waiting for an opportunity to interview the first suspect (It's an hour's drive from here) |
I would not go over 100,000 miles without doing timing belt (and water pump).
Tags |
2004, advice, purchase |
Thread Tools | |
Display Modes | |
need some advice | 4SPEED | General PT Cruiser Discussions | 1 | 13 Apr 2011 03:02 pm |
Need help...advice | careyk | General PT Cruiser Discussions | 7 | 17 May 2010 01:20 pm |
Please help...I need some advice. | Rainman | General Turbo Discussions | 14 | 10 Aug 2004 11:10 am |
Need advice | Pyropathic | Exterior Accessories Forum | 4 | 09 Aug 2004 06:47 pm |
Any advice? | jsp70 | General Turbo Discussions | 11 | 02 Aug 2004 10:48 am |
