Go Back   PT Cruiser Forum > Marketplace > Classifieds: Want To Buy
2006 cooling fan wiring harness
Old 31 Mar 2016, 01:45 pm
kctobyjoe's Avatar
Angry 2006 cooling fan wiring harness
My 06 had a major cooling system replacement.
Mechanic FAILED to connect the fan harness to the cooling relays; it manged to 'get loose' and mangle itself into oblivion dragging in the road ;-(
ALL The fan assemblies I see at MY local yards are stripped; Most are 2001 and 2002; devoid of relays anyway
I need the Y part that goes around the bottom and connects to the two relays on top of the fan assembly
A NEW fan will set me back another $80-$100 and I find that RIDICULOUS for just a 24" section of wires and an end connector
CAN ANYONE HELP?
Old 31 Mar 2016, 02:07 pm
Default Re: 2006 cooling fan wiring harness
I will look the next time I go to the pull a part, but I've not seen a PT newer than 03 there yet. Probably go one day next week.
Old 31 Mar 2016, 02:18 pm
rckstein's Avatar
Last edited by rckstein; 26 Apr 2016 at 12:13 am. Reason: Removed because some other member wants to run the entire forum
Old 31 Mar 2016, 07:57 pm
CAN ANYONE HELP?
I have the original radiator fan I took off the 2007 PT Cruiser. The only thing is that I had to cut the 4 pin plug off of that one. Other than that the wire harness is fine if you are interested in it. All you need to do is pay the postage.
Old 01 Apr 2016, 06:41 am
kctobyjoe's Avatar
I don't know if I could secure the right end connection...
The fan was replaced MONTHS ago and appeared to run fine; I don't know why I didn't look at the relay assembly for some time until it started to act up
WHY it didn't act up prior to this is a mystery
what do U need for postage to send this?
MY Post Office has these flat rate Priority Mail bags and boxes that will ship for like $6.25 or so $ dependent on size of FREE packaging...
TELL ME HOW YOU want to get paid or a TRUST deal I send U The cash
My PAYPAL is screwed up right now so not a viable deal
Joe
Joe Madajewski
4 Hay Street
Nanticoke PA 18634
There is a HARRY'S U PULL IT located in my neck of the woods; two in fat one in Hazleton and one in Allentown; THEY have Cruisers but its a crap shoot if harnesses and fans are still there. Considering the assembly is physically attached to the fan who knows UNLESS it is a front end smash...
Old 01 Apr 2016, 06:53 am
kctobyjoe's Avatar
Check with NAPA for the harness that you need. Recently the fan was replaced on my PT. But a couple of weeks later it wasn't running properly. Took it back to the shop that did the work and they discovered a bad connector on the piece of harness that you need. I think they got the replacement harness from NAPA, so check with them. I think they said it was around a $30 part, but they didn't charge me because they had just replaced the fan assembly. It plugs into the relays and then back somewhere to plug into the main harness.
I looked at NAPA's web site; MANY harnesses none look like what I need
you still have a p[art number by any chance?
Joe
Old 01 Apr 2016, 10:51 am
Here is the part numbers off the original radiator fan on my 2007 PT Cruiser.
Bosch Assy CES F00HX0G023
Part 6 004 HG0 041-10
ASSY OEM 6 004 HAO 000
I am being to wonder if you are better off buying a new radiator fan. The labor cost of repairing an wire harness and a new 4 pin connector might be high.
If I were you and I was going to keep the PT Cruiser for a while I would just buy a new radiator fan and keep the original fan with no harness for a spare. When the new radiator fan goes bad then you can take the harness off of that one and put it on the original fan.
Old 01 Apr 2016, 10:56 am
LionPT's Avatar
CAN ANYONE HELP?
Used Fan Relays w Plugs Chrysler PT Cruiser 2006 11 Free S&H | eBay
Old 01 Apr 2016, 11:11 am
The 4 pin connector from the Ebay link above has a metal attachment on it that I don't have on mine. You might want to make sure yours has it.
Old 01 Apr 2016, 11:55 am
kctobyjoe's Avatar
Unhappy Re: 2006 cooling fan wiring harness
Bit the bullet bought a NEW entire fully wired assy
Its only 5 10MM bolts; just a little tight
SCREW IT. NO RUNNING; JUST A WAITING GAME NOW :-(
Cut wiring harness - UGH!! binptguy Tech & Performance Forum 4 15 Jul 2012 04:06 pm
Wiring Harness mnso123 Classifieds: Want To Buy 0 07 Jul 2012 02:09 pm
wiring harness BeagleDad Classifieds: Want To Buy 0 09 Dec 2011 02:05 pm
Wiring harness 99PlyNeon General PT Cruiser Discussions 4 19 Jul 2011 11:09 am
