Go Back   PT Cruiser Forum > Marketplace > Classifieds: Want To Buy
Need power steering pump reservoir. The square one. 05 GT MT. And timing covers
Old 28 Oct 2016, 11:09 am
Default Need power steering pump reservoir. The square one. 05 GT MT. And timing covers
My reservoir is cracked and leaking, in the middle of a timing belt job. So easy time to replace it.
Also need timing covers, all 3 plastic covers.
Quicker the better. Have PayPal ready. Live near Tampa Fl.
Old 29 Oct 2016, 06:39 pm
Default Re: Need power steering pump reservoir. The square one. 05 GT MT. And timing covers
Both of these are available from Rockauto.com. The timing covers are cheap, but the reservoir is more expensive.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 29 Oct 2016, 06:43 pm
Ya I checked, the res is almost $200. I know I can find it for way cheaper than that in good working order
Old 29 Oct 2016, 07:44 pm
VsandFords's Avatar
Have you checked your local "U pull it"?
Old 29 Oct 2016, 07:49 pm
Rock auto is way too much for the res. I know I can find a cheap good working one.
All the yards here so far are round reservoirs.
Gonna keep searching
VsandFords likes this.
Old 30 Oct 2016, 12:10 am
The reservoir is not an easy part to find
Good luck with it
You can check on FB srt4 parts , I found my pump with the res like that
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 30 Oct 2016, 05:54 pm
If you guys could educate me on why some are round and some are square and why they don't interchange, I would appreciate it.
Old 30 Oct 2016, 05:59 pm
The square one is connect directly on the the steering pump,
The round is connect with a oil line
Are you sure your steering pump reservoir is crack ? there is a small o ring who brake sometimes
Old 30 Oct 2016, 06:02 pm
Ya when I replaced the pump the the res was beat up. I repaired it with jbweld and replaced the o ring and tested for leaking. No leaking on that test. But under pressure it could be leaking.
Id like to replace it anyway but the square ones are hard to find used
Old 30 Oct 2016, 06:12 pm
yes like I said check on FB the SRT4 parts
2003 pt turbo power steering pump to reservoir o-ring question walleyeman General Turbo Discussions 2 24 Jul 2016 11:42 am
Turbo Power Steering Pump Reservoir Ikster Tech & Performance Forum 0 17 Oct 2015 01:04 pm
power steering reservoir 03ptatx Tech & Performance Forum 1 18 Jan 2015 01:11 pm
Power Steering Reservoir DIY glassbuggy Tech & Performance Forum 13 14 Jan 2015 07:17 pm
Power Steering pump/reservoir o ring question billybob123 Tech & Performance Forum 10 07 Jan 2014 02:41 pm
