Go Back   PT Cruiser Forum > Marketplace > Classifieds: Want To Buy
Desperate need of a thermostat housing
  • 1 Post By myckee
Old 22 Feb 2017, 07:24 pm
Default Desperate need of a thermostat housing
I am looking for a lower (metal) thermostat housing. I stripped one of the bolt holes. I need it by the weekend and will pay for expedited shipping if reasonably priced, Thanks
03 Turbo GT
Zip: 21234
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 22 Feb 2017, 08:08 pm
rob302's Avatar
Default Re: Desperate need of a thermostat housing
Where are you located? .... Nevermind i must be a bit retarded.. MD
Are non turbo lowers the same? I'll see if i can get mine off with no real tools, if so you can have it free. Anyone else feel free to offer one up in the meantime
Old 22 Feb 2017, 10:23 pm
The non-turbo is the same, but the temp sensor screws in on the side of the Turbo ones, and in the front on the non-turbo. Since the powersteering reservoir is directly in front, to use a non-turbo one in your turbo car, you would have to plug the front temp sensor hole, and then drill and tap the side indent for the temp sensor.
I have a turbo one here. I am in Ontario, Canada. If you really need it by the weekend, I can probably get a quote for overnight FedEx shipping to you, but I doubt it will be cheap.
If you live close to a junkyard, these are the same parts used on all PT cruisers and all Dodge Neons(only the temp sensor location differs as described above) so they are very plentiful and cheap. This is probably your best option.
rob302 likes this.
Old 22 Feb 2017, 10:52 pm
_PTGT03's Avatar
there for sale and in stock at rockauto
Old 22 Feb 2017, 10:55 pm
rob302's Avatar
Will this one work, or does something physically prevent it?
Just removed it and cleaned it up:
https://goo.gl/photos/kAy8zuMpYNv1vBEH6
Old 22 Feb 2017, 10:58 pm
rob302's Avatar
Nevermind i just read myckee's post.
I can ship this out in the morning for free if you like.
Old 23 Feb 2017, 02:53 am
Depending on which hole is stripped, You could put a nut on the bottom side if there is room, or maybe drill a little deeper and use a longer bolt after re-threading the hole using a bottom tap.
The steel bolts used in the aluminum head may break if your not careful removing then causing more problems..
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Feb 2017, 06:28 am
Thank you but it wont work because of the PS pump in the way. I appreciate everyone for trying to help. I was trying to avoid the upullit yard due to time constraints but it may be the only option.
GT thermostat housing removal gmrviper General Turbo Discussions 17 12 Sep 2016 01:50 pm
thermostat housing leak? How to fix it? postbeauty General PT Cruiser Discussions 13 20 Feb 2015 05:12 pm
Car temp climbing after thermostat and thermostat housing replaced. superjew78 General PT Cruiser Discussions 23 04 Jun 2014 02:37 pm
Thermostat housing cowboyinboxers Tech & Performance Forum 11 20 Oct 2012 06:51 pm
Thermostat housing replacement SRT8guy Tech & Performance Forum 5 12 Nov 2008 12:43 pm
