Go Back   PT Cruiser Forum > Marketplace > Classifieds: Want To Buy
Hatch Lift Gate Struts
Old 25 Nov 2018, 08:05 pm
mjb457's Avatar
Default Hatch Lift Gate Struts
Does anybody have or know where to get decent struts---aftermarket ones very stiff--( will they loosen up?) thanks
Old 25 Nov 2018, 08:54 pm
rckstein's Avatar
Default Re: Hatch Lift Gate Struts
I like the OEM ones. The hatch struts were replaced in 12/11 when my PT was still under an extended warranty.
They installed MOPAR 4589630AC struts and MOPAR 6509297AA Stud.
My PT now has almost 92,000 miles on those struts and they still work as good as when new, no problem holding up the rear hatch, and I use my hatch several times almost every day, so they get plenty of use.
RockAuto has a real good price on the OEM, $28.79 where most other sources are almost $44/each:
https://www.rockauto.com/en/parts/mo...t+support,1404
And $1.85/each for the mounting stud (you will need 4 for the initial installation):
The advantage of using the OEM type with the mounting stud is that you only have to install the stud once, if the struts need to be replaced in the future, you just pop them off the stud and snap on the new struts.
Most replacement struts you have to mount with a screw attached to the strut.
One disadvantage of this type is that you risk cross threading the mounting screw while installing the strut. Again, with the stud type, you only have to mount it once and never worry about cross threading it again.
Old 26 Nov 2018, 11:52 am
I got mine at Autozone. Mightylift brand. They were easy to change and worked great. Make sure you prop that lift gate open with a 2x4 or something when you change them. One will not hold it up. I didn't replace the screws. I just popped the clips off the old ones and tapped the new ones in.
Old 26 Nov 2018, 12:06 pm
Sinbad's Avatar
Real men use a lump of 2 x 1
Struts!? We don need no steenkin struts!
_________________________________________
'07 2.2 CRD
Old 26 Nov 2018, 01:24 pm
LionPT's Avatar
Basically, Yes. The more you use the hatch, the more the oil will coat everything. Probably about a week or 2 under normal use.
Old 26 Nov 2018, 01:42 pm
mjb457's Avatar
Thanks
Old 26 Nov 2018, 02:15 pm
Handy_Cruiser's Avatar
Here's may choice. They are US-made with a lifetime warranty.
https://www.amazon.com/StrongArm-CHR...StrongArm+4564
Old 27 Nov 2018, 11:02 am
Macgyverman1123's Avatar
I used QImax, I like them, no issues.
PS: keep a 2x4 handy for installation
Old 10 Nov 2019, 12:52 pm
mjb457's Avatar
Handy Cruiser---9above -Amazon-USA--perfect same a OEM!!! thanks installed --overseas ones junk-- thanks
lift gate keeps opening itself themary General PT Cruiser Discussions 14 08 Nov 2017 11:56 am
Rear hatch lift struts PurplePTGirl General PT Cruiser Discussions 30 15 Jan 2016 08:21 pm
Hatch/lift gate struts j0e General PT Cruiser Discussions 5 23 Feb 2013 02:06 pm
01 lift gate hatch handle jessica7137 Classifieds: Want To Buy 5 12 Jul 2011 08:44 am
CUSTOM REAR LIFT GATE/HATCH namvetmike Exterior Accessories Forum 6 06 Jan 2004 07:32 pm
