Guide to Detailing Your PT: Claying Your Paint
Old 30 Jul 2008, 05:04 am
Candyman's Avatar
Exclamation Detailing To Guide: Claying Your Paint
Hello everyone,
Welcome to our next segment in our Guide to How to Detail your PT like a Pro!
Before we begin, lets get a little insight on what a Clay Bar is, and how it works!
Clay bars are designed to remove most types of paint contamination which can usually be broken down into three catagories.
1. rail dust: Produced by friction of train wheels as they make contact with the track. 70% of all vehicles delivered throught the United States are delivered by rail making this a big problem for paint contamination.
2. brake dust: Produced by friction of brake pads against the rotor dispensing microscopic metal shavings that collect on the paint surface.
3. Industrial fallout: AKA pollution. Bio-chemicals that disburse airborne particles that love to eat your paint.
These contaminates will cause the paint to feel rough to the touch, and cannot be removed by waxing, polishing, or buffing your paint. Unlike compounds, clay bars do not etch, or remove paint, and can be used as often as you like. The cost is approximately $25-$30 with a life expectancy of 5 to 6 uses before discarding. For those of you unsure of how to use this product, here's the basic idea.
Before you Clay your PT, it is a good idea to check your paint to see if you have surface contaminants. These contaminants range from rail dust that was left on the surface, to brake dust particles expelled from other cars on a busy freeway. Here is an example of just a few contaminants that can be found on most paint surfaces.
To check for contaminants, simply place your hand in a plastic sandwich bag, and run your fingers across the paint surface. If it feels smooth like glass, then you do not have contaminants, however if it feels rough to the touch, then you should remove the contaminants before proceeding. The best way to remove these contaminants is with a Clay Bar. The process is simple, and unlike buffing, Claying will not damage the surface, and can be performed as many times as desired without fear of damaging your paint.
As always recommended it is a good idea to work on paint that is out of direct sunlight, and cool to the touch. Like wax, work in a small area of about two to three square feet at a time. Mist the section with a good lubricant (as an example, if you use Meguiar"s quick detailer, or final inspection which are available at most retail stores works fine) and simply glide the clay bar across the paint till it is smooth and the clay bar glides freely. Wipe any access with a clean microfiber towel, and continue till you've completed your ride. Even though clay does not cut the paint, it can remove some chemicals used in lee expensive wax, so it is a good idea to follow up with a fresh coat of wax when your done.
QUICK TIP
Just like paint, your glass can also contain these same contaminants, and may be mistaken for tiny pits in the glass, but are actually on the surface. These contaminants can also be removed with the Clay Bar process, to restore clarity, and improve the overall look of your PT.
I hope you enjoy my Tutorial's, and thank you very much for reading my Guide to Automotive Detailing! Till next time, take it easy, and we will see you a little further down the road!
For more great information on Professional Automotive Detailing, please check out:
Company & Forum Announcements - Car Care Forums: Meguiar's Online
Or check out our Meguiar's Inside man and Custom PT Owner Michael Stoops for the latest deals on all your Detailing Chemical questions, or needs and be sure to tell them the Candyman sent you!
Michael Stoops
Surface Care Specialist
Meguiar's Inc.
(800) 347-5700 xt 175
mstoops@meguiars.com
Candyman
Old 01 Aug 2008, 03:15 pm
Candyman's Avatar
Default Re: Guide to Detailing Your PT: Claying Your Paint
Reposting in correct order
Guide to Detailing Part 1: Introduction Candyman The Detail Shop 3 01 Aug 2008 04:12 pm
Detailing How to Guide Washing your PT Candyman The Detail Shop 1 01 Aug 2008 03:16 pm
Claying instructions>Print turbomangt The Detail Shop 1 01 Oct 2004 08:05 am
Autopia Detailing guide. No Need to download Here jonw440 The Detail Shop 7 04 Aug 2004 03:15 am
Aautopia Detailing Guide v 3.3 is out jonw440 The Detail Shop 0 15 Jul 2004 11:11 am
