Air Brush Tricks and Effects
Closed Thread
Old 02 Apr 2010, 06:49 am
Candyman's Avatar
Smile Air Brush Tricks and Effects
Hey Everyone,
Ever wonder how Custom Painters are able to paint simulated Carbon Fiber, or a Brushed Aluminum Effect? How about realistic looking Wood Grain, or 3D Water Droplets that look like they are embedded into the Paint?
When it comes to Custom Paint Work, their are a lot of really simple effects that are done using really surprisingly easy techniques to get very cool, and unique results. Here are just a few secrets to doing Custom Paint that anyone can do at home! All it takes is a little practice, and you can pull off some professional results!
I will start posting some write ups on how to do some of the hottest Custom Paint Effects, and how they are done, and will follow up with How TO Video's from some of the best known Air Brush Artists around so you can see how these effects are actually done. I hope you enjoy these Write Ups, and maybe even become inspired to pick up an Air Brush and give it a try! Its not hard to do, a lot of fun, and you never know, you just might find a hidden artist in you that you never knew existed!
1. SIMULATED CARBON FIBER EFFECT
Simulated Carbon Fiber is actually a really hot ticket item right now in the Custom Paint community! Their are a lot of Aftermarket Carbon Fiber Parts available which both reduce weight, and kind of have a cool different look to them with their weave pattern look. The more popular these Parts get, the more people are wanting to paint other parts to match. With that said, you would think Carbon Fiber would be insanely hard, and tedious to pull off that kind of a custom look in paint, but its really not that hard at all!
To pull off this look you will need, preferably an Air Brush, but you can also use a regular Spray Gun and achieve a decent result. Also, for practice purposes, you can also use spray paint to get a feel for this effect.
Next you will need a couple of friends, a black painted surface which will be used as your base background for practicing on before you go ahead and do parts on your PT. Then some bright silver paint, and some darker more charcoal paint, and as big of a roll of that rubber liner you line kitchen cabinets, and drawers with. Here is a photo for ya. I believe it should be somewhere in the neighborhood of $2.50 a roll.
With a clean black painted surface that is prepped for paint, you are going to want to have one friend stand at each end of your panel, and hold your Rubber Shelf Liner tightly stretched over your panel which will give you that tightly woven Simulate Carbon Fiber Effect you are going for.
With the Liner pulled tightly as possible, start spraying an even flow of your bright silver paint across your patten panel. Make sure you do as light of coats as you can to best pick up the effect.
Once the Paint has had enough time to Flash, you want to match up your Rubber Liner with the pattern you have just sprayed out. Then take your gun, or Air Brush and mist a coat of darker (I prefer Metallic but its not necessary). Once the Graphite has been sprayed out, take the rubber mat off the panel, and you should have the basic effect.
Once everything dries for the specified time given by the Paint Manufacturer, then lay down at least 4-5 Coats of Clear Urethane, and you should have a really cool looking Panel!
As with most anything involving Custom Paint, it just takes a little practice to get it down. Their is no right, or wrong, and its always fun to experiment, change up colors, and try new stuff. Make sure you practice first on a test panel, or hit up a wrecking yard and ask if you might be able to get them to donate an old hood, or door, or something to practice on before you try it on your car.
Now, I know that words often mean one thing, while actually seeing it being done in person is a whole mother thing all together, so, here is a Youtube Video Tutorial outlining basically exactly the same steps I just talked about in the Write Up which was done by Renowned Air Brush Artist Ed Hubbs.
2. WATER DROPLET EFFECT
Like most of the effects I am discussing here, the Water Droplet Effect is very simple to do. It just takes a bit of practice to pull off a really cool 3D Effect.
First take a Test Panel which has been pre-coated in Cobalt Blue which is one of my favorite colors, for this example.
First wipe down the panel with wax and silicon remover and prep it for paint.
next fill up a spray bottle with some water. I like to use distilled bottled water so as to not potentially pick up any salt, or other contaminants that could be in tap water.
Then spray droplets of water onto the panel. The larger the droplets, the better for this effect. Once you have droplets on your panel, grab an air brush or mini jet premixed with some silver paint for this example, and lightly mist one side of the droplets themselves.
Be extremely careful not to bump or move the panel as it could ruin the effect. Let the panel dry overnight, and once the water evaporates, the 3D water droplet effect will be left on the panel.
It is very simple to pull off, but takes a bit of practice to get it to come out right.
Just like before, here is a good Youtube instructional Video from one of my favorite Air Brush Artists Ed Hubbs to give you a better visual of the effect, and how it is done.
BRUSHED ALUMINUM OR METAL EFFECT:
Here is another simple effect that you can easily do with just a little practice. This is probably one of the all time easiest effects to pull off by far, and is very similar to how you would do a simulated wood grain as well.
For this type of illusion, its best if you have a test, or practice panel already sprayed with a black base which will act as your background or base color.
Next you will want to spray a medium coat of bright silver over the black, and right after you finish spraying while the paint is still semi wet and tacky, take a fine one coat paint brush (I use a good 2") and simply streak the paint in a downward motion to create the effect.
Then let the paint flash for approximately 15 minutes or as directed by the manufacturer, and shoot your clear over that to a nice high gloss finish.
Let everything dry overnight and color sand, buff, and finish.
Then stand back and admire your work. It can't get much simpler than that.
This type of effect can be done on flames, or any type of a side graphic where you would like more of a metal kind of look going on.
As always, it is one thing for me to explain it, but another to have a good visual of what the heck I am talking about, so here is my favorite Airbrush Artist Ed Hubb with a video demonstration so you can actually see what I am trying to describe.
A lot of Airbrushing is really fairly simple to do. All it takes is just a little practice, and anyone can do it.
Please keep checking back on this Post as I will keep adding more and more effects for you including getting into doing some more advanced things such as painting skulls, and even true fire flames as well, and if you ever have any questions on any of the information above, please feel free to ask me anytime. You can either reach me here on the Forums, or by Emailing me direct at:
westvalleycruisers@yahoo.com
Go easy, and I will catch yall later.
Candyman
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Please Like my Hot Rod Restoration and Detail Shop on Facebook.
https://www.facebook.com/BlueDiamondDetailing
Old 02 Apr 2010, 09:54 am
William_F's Avatar
Default Re: Air Brush Tricks and Effects
You have good timing. I was just saying I was thinking about an airbrush again. Of course, I never thought I'd see the day you would recommend some one lay their own paint!
Old 02 Apr 2010, 10:19 am
Candyman's Avatar
Hey their Will,
As long as they start out on test panels and such I hope. Yeah
Naw man, I just picked up one of these a few weeks ago and have been trying to get back into playing around with things again. Got 3 mail boxes and some supplies. Up till now, I have been kind of using mostly my Mini Jet but its as close up and fine work
http://www.coastairbrush.com/proddetail.asp?prod=K9000
I'll have to post some of my stuff after I get a tad bit unrusty first
Old 02 Apr 2010, 04:36 pm
William_F's Avatar
I thought my car was a practice panel
I've been thinking a nice stainless steel modesty cover with a little artwork would look good when I get to playing under the hood.
Now I have to decide if I want to buy an airbrush or if I want that chrome strip for the hood....
Closed Thread
NGK Iridium Plugs...Questions I asked the tech crazie.eddie Tech & Performance Forum 10 28 Oct 2004 10:46 pm
Asked about S2 at the MoPar Nats last weekend im4gzs Stage Turbo Kits 6 19 Aug 2004 02:59 am
Gary..you asked about the RIP CREWZIN The Detail Shop 9 30 Mar 2004 11:43 pm
You asked for it> turbomangt Vendors & Buyers Forum 3 07 Aug 2003 10:27 am
