Water Spots
Old 07 May 2004, 01:57 am
Default Water Spots
I washed/polished/waxed my PT today. I noticed that there are still a good bit of tiny swirls and a lot of water spots. I used Meguiar's cleaner wax and gold class wax. I just clayed the car a few weeks ago, and there were still a few water spots on it then. Any suggestions?
Old 07 May 2004, 12:23 pm
http://www.ptcruiserlinks.com/forum/...ms=water,spots
Old 09 May 2004, 04:43 am
[:I]You lost me QSD. I looked at the link. Do you think a clay bar works. If so where do you get one I've never seen one before. After using it then I get to use a real good wax.
Old 09 May 2004, 11:48 am
Stirfry, let me try to clarify. Your clearcoat is about 2 mils thick, (take a piece of notebook paper, that's about 2 mils) Whenever a contaminant hits your finish (water spot, bugs, bird bomb, overspray and on and on) if it is not removed right away, the process of "etching" has started. If the contaminant has only been on the surface a short time, chances are if can re moved during the wash cycle, or "deep cleaning" cycle. The problem with water spots and bird bombs is that it doesn't take long at all before the etching goes through the clear coat and into the base coat or color coat. Clay bar, paint cleaners will only work if the etching has not started. Gary
Old 09 May 2004, 02:10 pm
Thanks Guys; leaves me with just one question. Where do I get a clay bar. Gary, I looked at you sight, and with all your help I really feel I have a much better understanding on the subject. Do you sell the clay bar, if not where might I get it. Mahalo,[8D]
Old 09 May 2004, 06:26 pm
Stirfry, for those that have trouble finding clay, I will sell you at my cost if that helps you out. Just write in and add $10 to the order form and I will get you a piece of clay enough to do 5 cars. My spray and shine is the lubricant to use with the clay. Order form can be downloaded from my web site. Gary
Old 09 May 2004, 10:30 pm
Thanks Gary; I'll do that, I tried the Meguiar's NXT it works good on most of car. But doesn't get some water spots that were gotten from a sprinkler. Also when I got the car the shipper accured some contaniment specks. Really showed up on a white car, could never figure out what it was, mostly all gone but some specks remain. Hopeing the clay bar does it. Thanks again for the help.
Still got Water Spots jmack The Detail Shop 4 12 Jul 2004 11:55 pm
pillar water spots Shini Quiet The Detail Shop 2 27 Jun 2004 09:43 pm
water spots BLH1 The Detail Shop 10 07 Apr 2004 10:37 am
Window Water spots knowyourturbo The Detail Shop 14 12 Dec 2003 01:40 am
How to remove water spots from windows? beard General PT Cruiser Discussions 9 06 Oct 2003 09:20 am
