water spots on glass
Like Tree4Likes
Old 28 Nov 2016, 10:03 pm
Default water spots on glass
Has anyone tried 0000 steel wool? I have ried everything and wondering if this was safe to use. I had heard of an article somewhere to do this.
Old 28 Nov 2016, 10:13 pm
Default Re: water spots on glass
You are better off using glass cleaner and a single edge razor blade.
Somewhere on this forum we all talk about glass cleaning/polishing but I don't know where that thread is.
Here is the info on another PT cruiser forum.
Glass cleaning Pt Crew
Glass cleaning
PTCrew.com - View topic :: Glass cleaning
Old 28 Nov 2016, 10:22 pm
I have tried that many times and never once had any results.
My wife just reminded me the article and demo was on youtube
Old 28 Nov 2016, 11:08 pm
_PTGT03's Avatar
you have to use a heavy polishing pad with a heavy cut cleaner. i had a car with this problem and polished the glass. sometimes if the acid etching is not too deep you can use a chemical cleaner like chemical guys water spot remover
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. issues: lower than expected boost, PCM in progress of replacement and tune with Syked Software
Old 29 Nov 2016, 08:52 am
Try a little CLR on an inconspicuous spot. Calcium, lime and rust remover.
Ignorance can be educated, crazy can be medicated but there's no fixing stupid!
Old 02 Dec 2016, 12:26 pm
Turbodude06's Avatar
This is the best method, if the steel wool doesn't work. Just make sure it's the "fine". The course can scratch the glass, I use it all the time tinting windows so I know it's safe but I doubt it will work on water spots. Buffing works and is super easy.
2004 PT GT 5-Speed! Project "THE RIDDLER"!!!
http://www.ptcruiserlinks.com/forum/...t-5-speed.html
Old 02 Dec 2016, 12:32 pm
Just to consider? Most glass is not without imperfections over years. Using wax may be as hard to remove as the water spots when the wax dries in all the little nicks and small particle impact damage like you see on windshields?
An "old school" car show secret...and forgotten glass polishing trick.Steam distilled water and newspaper...try it!
Some cleaners or the cause of etching in the glass. You can get glass rouge in a stick. And buff the glass. Don't recommend the steel wool.
Old 02 Dec 2016, 01:25 pm
PGBCruiser's Avatar
Interesting timing for this topic... Autogeek just did a review of a Griots Garage product that applies. Mike Phillips is brilliant; and a very good guy. Very generous with his time and knowledge. I'm guessing the technique is applicable to different brands...
Review: Griots Fine Glass Polish - How to remove water spots and road film off car glass
I have a few other items to take care of first; but I may try this within the next 6 months or so.
Old 02 Dec 2016, 02:06 pm
WOW! I have never had to go to extremes like that on any vehicles glass ever!!
Water spots. air4cefamily The Detail Shop 8 26 Jun 2008 11:39 am
Still got Water Spots jmack The Detail Shop 4 13 Jul 2004 12:55 am
pillar water spots Shini Quiet The Detail Shop 2 27 Jun 2004 10:43 pm
Water Spots CHROMEDCRUISER The Detail Shop 6 09 May 2004 11:30 pm
water spots BLH1 The Detail Shop 10 07 Apr 2004 11:37 am
