DIY bodywork after accident
Like Tree14Likes
Old 01 Feb 2017, 01:08 pm
Default DIY bodywork after accident
Well, my teenager and his friend on a motorcycle somehow ran into each other in a parking lot.....damage to driver quarter panel, both driverside doors, and the rocker panel. Neither moron was harmed.
The panel and doors are easy enough...He's just going to locate replacements in a salvage yard. The rocker panel is where we need some advice.
What's the best way to pull these dents out so they can be hammered back near shape? What's the best way to fix that big ole hole?
I figure once we have it near shape, we can apply bondo, sand, prime and paint the rocker back to normal...or near enough.
2009 Base PT. White. 115K as of 1/2016
Added cruise control.
Maintenance/Repair Achievements Unlocked: Radiator fan. Ball joints. Wheel bearings. Timing belt. H2O pump. Front Struts.
Old 01 Feb 2017, 01:44 pm
_PTGT03's Avatar
Default Re: DIY bodywork after accident
best way to do the rocker panel is cut and weld a section from a good car.
pulling the dents best to use a spot-welding slide hammer.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 01 Feb 2017, 01:53 pm
LionPT's Avatar
If you decide not to weld a replacement rocker panel, I would fiberglass it.
67Therapy and VsandFords like this.
Old 01 Feb 2017, 02:16 pm
rckstein's Avatar
Ouch
So which one won, the PT or the bike
67Therapy likes this.
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
Old 01 Feb 2017, 02:53 pm
You need to know that the rocket is not a straight line front to back. Rather a long curve like a boat. If you going to repair this you might want to make a cardboard template of the other side to guide you in the alinmentyof the metal. You he somebody with welding skills to help you on the hole.
67Therapy, ptprice and rob302 like this.
Old 01 Feb 2017, 05:26 pm
Great. Thanks! I'll do that.
Old 01 Feb 2017, 05:27 pm
VsandFords's Avatar
If you have the skills and access to a welder, that would be what most people consider the "correct" repair. If you are talking about a backyard, low budget, DIY repair, fiberglass is a good, cheap and easy fix. When prepped right, it will last for a long time. Possibly longer then the Cruiser. There are some slide hammer dent pullers that you can purchase from places like Harbor Freight for cheap.
How ever you decide to fix it, good luck with the project and keep us posted. I am always interested/nosey in how things work out!
67Therapy and ptprice like this.
Old 01 Feb 2017, 05:30 pm
Originally Posted by rckstein View Post
Sorry which one won, the PT or the bike
I think it was declared a draw.
Can you rent those or am I off to HF? I thought about cutting/welding in a new piece...would be best, but my welding skills are pretty poor.
Yeah, I think this will be the way...
Old 01 Feb 2017, 05:32 pm
Low budget, DIY is the way I'm leaning. I'll be sure and post back on our progress. Thanks for the input and help!
Old 19 Feb 2017, 05:52 pm
I'm progressing slowly...been out with a cold and haven't been able to do any work lately. I previously pulled the dents from the rocker panel with a screw and dent puller...I drilled about 1 million holes I think. I even got the tear in the metal bent back "close" to shape. I used Bondo short hair fiberglass over the rocker repairs and then covered that with regular bondo gold. It looks pretty good, but it wouldn't pass muster at a real body shop I'm sure.
A week or so ago, I found two perfect doors in the same paint code at the salvage yard! The pinstripe is the wrong color, but that's easy enough.
They also had a front fender that wasn't bent, but it wasn't the right color. I've sanded it down to metal.
In the next few days, provided I'm over my cold. I hope to start painting. I've never painted before. Don't laugh, I'm gonna do it with aerosol cans. I'm using a 2-part Spraymax primer, color-matched PPG in a can, and a 2-part Spraymax clearcoat.
I probably could have just done the fender and it would have been "close enough", but I just couldn't help myself and started taking down the clearcoat on the driver door so I could blend the fender and door. Do I have to remove all the clearcoat on the door or do I just rough it up and make it dull? I used a 3M ultra fine scotchbrite pad, but I'm not sure I've taken enough clear off...how do I know?
Car accident Luska General PT Cruiser Discussions 59 29 Jul 2015 11:51 am
IN A ACCIDENT! butterfly_pt_01 Tech & Performance Forum 25 09 Mar 2014 05:53 pm
PT in accident! thegoldpt General PT Cruiser Discussions 6 19 Oct 2005 02:32 pm
accident 026TB4U General Turbo Discussions 5 23 Feb 2004 02:01 am
Pt Accident...... studymunguy General PT Cruiser Discussions 12 18 Nov 2003 08:44 pm
