Master Detailers: Can Compounding Help?
  • 1 Post By _PTGT03
Old 04 May 2018, 09:38 pm
Macgyverman1123's Avatar
Default Master Detailers: Can Compounding Help?
Evening everyone!
This question is for the detailing masters here.
My '02 LE has some weird "Deposits" on the back driver's panel and c pillar. It almost looks like a resin, if you will, on top of the paint. It is also spidered all over. When I look really closely and when it fades back to normal paint, it appears to be on top of the clear coat. Could this be perhaps tree sap, or is it damaged clear coat?
Would compound/polishing remove this, or would it take off any remaining clear coat?
I really want this off my poor car, it's been there for several owners, from what I understand.
I love keeping a clean car, but I am Leary of the idea of sanding away at the paint. I will try to get some macro photos of the issues uploaded tomorrow. In the mean time, I greatly appreciate your feedback.
Old 05 May 2018, 08:02 am
Default Re: Master Detailers: Can Compounding Help?
If it's tree sap the easiest (and cheapest) thing I found to remove it is rubbing alcohol with a soft cloth. It won't hurt the paint.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 05 May 2018, 05:21 pm
rcktpwrd's Avatar
Cool Re: Master Detailers: Can Compounding Help?
Pics would be very helpful to help diagnose what it is and what can be done.
Seeing it in person would be even better... I have some experience with buffing/polishing vehicles.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 05 May 2018, 06:01 pm
Rocket, I'd love to show you!
Check your personal messages, I sent you my number. Send em a text!
Old 05 May 2018, 11:59 pm
_PTGT03's Avatar
Originally Posted by Macgyverman1123 View Post
Evening everyone!
It could very well be over-spray from a paint job done in the past.
Tree sap is obvious as it's drops.
Best way to remove tree sap is to spot-heat it with a heating gun until the solid form just starts to melt. And then wipe with a rag soaked in tuolene or acetone and within minutes its gone
rockandroller likes this.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 13 Jun 2018, 01:43 pm
rob302's Avatar
before wiping toluene on anything, hold the rag in an inconspicuous spot for a few seconds and scrub. let it evaporate and inspect the paint. i've damaged two paints recently with xylol, which is weak compared to toluol
Old 13 Jun 2018, 02:29 pm
rcktpwrd's Avatar
As a follow up, Macgyverman1123 and I meet up and I looked over the paint and it is shot... the clear coat is damaged beyond repair unfortunately.
Joel
www.rcktpwrd.com
Old 14 Jun 2018, 04:17 pm
Yes, sadly the clear coat is not fixable. But, that just gives me another fantastic excuse to do a full restoration of the car!
bad master cylinder or bad abs Coydog General PT Cruiser Discussions 16 22 Dec 2014 07:03 pm
Looking for Master PWR Window Switch jeffv1970 Classifieds: Want To Buy 7 07 Aug 2014 12:45 pm
Clutch Master Cylinder discovering06 Tech & Performance Forum 4 10 Jul 2013 10:27 pm
Master Key and alarm fob Jassy Tech & Performance Forum 10 05 Jul 2013 03:33 pm
Clutch Master Cylinder turbodog Classifieds: Want To Buy 0 04 Feb 2013 01:21 pm
