Rusted Roof Cavity Repair?
Like Tree10Likes
Old 12 Oct 2019, 02:59 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Rusted Roof Cavity Repair?
Help with finding a permanent or close to it, solution.
Have repaired this area twice but after about 1-1/2 yrs it comes back again.
Previously have cleaned rust, filled with caulking and shaped it, then painting with Rust-Oleum paint.
Suspect that regular caulking cures acidic and will rust.
https://i.postimg.cc/MKrtT74P/20191012-153917-HDR.jpg
https://i.postimg.cc/tJ8Z04S5/20191012-153949-HDR.jpg
Thanks
2001 PT 117K Miles Ltd Edition (March 2022)
Old 12 Oct 2019, 03:39 pm
Default Re: Rusted Roof Cavity Repair?
There is lots of rust that was not treated when you first did the repair. The rust continued under your first repair and became worse. No it may not be an east task to slow or stop it without cuting/grinding the rusted area out.
Be careful with what you use if oxygen is told sealed away from rust the rust will continue to increase under any repair you make.
Busted_PT and ptprice like this.
Old 12 Oct 2019, 06:01 pm
LionPT's Avatar
Fiberglass it or cut it out.
Old 13 Oct 2019, 07:25 am
Cut the roof off and weld on another one.
VNT likes this.
Old 13 Oct 2019, 09:32 am
ptprice's Avatar
My avocational hobby for over 60 was restoring vehicles. One at a time.
In every case rust had to be remove. The operative word being REMOVE.
A full body dip is preferred but in the case of your roof corner what you can't logically cut out must be similarly treated.
Eastman makes some fine liquid products. See attached.
In conjunction with or additionally, another repair adventure would be,
invest in an Eastman crimping tool, see attached, make a raid on your local salvage yard and with a battery powered saw or chisel and hammer, remove enough corner donor metal from a dead PT, put it in your pocket, cut it to shape back at the ranch, cut out the offending rusted corner, flange the edges and either spot weld, fiberglass, rivet or some combination, secure in place.
Finishing it will be the icing on the cake. That should make a permanent repair.
raeder likes this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chromed Side Spears, Grills, Fuel Filler Door, Door Locks, Handles/guards , PRND3-1 Bezel, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim. Cool Vanilla White shift ball, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry. Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers. Back up Camera, 7" Monitor.
Old 13 Oct 2019, 12:35 pm
soonercruiser's Avatar
Hey!
SIMPLE...
Rustoleum makes spray rust treatment..."converter"agent!
Use that before any type of paint as prevention!
https://www.zoro.com/rust-oleum-rust...E&gclsrc=aw.ds
BTW...how are you addressing the rust underneath the metal in that area?
The "above" on a paint brush might help!
Frank, aka SOONERCRUISER,
Old 13 Oct 2019, 07:22 pm
I use to restore BRITISH cars for a living!!!!!!!!!!!!!.... what a PIA.
None of the products that convert rust or supposedly STOP rust really work well in any area that there are lots of seasonal moisture.
In other words there are NO MAGIC chemicals. Rust is metal cancer and must be removed.
Some of the worst thing to use is anything that is Aerobic. That is pretty much all the chemicals. All they will do is slow down or mask the "CANCER" called rust.
If you are not experienced in advanced body repair this type of repair removing metal and re welding replacement parts is not advised. You will "frick" it up!
The investment in the proper and necessary tools is almost as much as simply paying a body shop to properly do the work.
Now if you intend to do other projects and maybe some on the side part time income to pay for your investment in the tools to undertake panel restoration replacement and repair then by all means give it a go!
Old 13 Oct 2019, 09:21 pm
ptprice's Avatar
Blair flanging pliars, $21.99 from Summit Racing, with a pop rivet gun or two part adhesive would be small price to pay to install a replacement insert.
It's not a long list of shop tools as mentioned. Just a few supplies to install a rust free replacement for that rusted roof corner.
There are dedicated adhesives used to secure flanged joints eliminating rivets or spot welds on small projects like this.
It's not a quarter panel, just an inner roof corner. I've used flanging pliers on the smallest of replacement "panels". The flanged overlap makes a perfect fit if carefully planned and the insert remains at true surface level at the over lap joint.
Wanting a permanent, properly done, rust free repair? This is one way to replace the rusted metal!!!
Happy PTin', ptprice
rockandroller likes this.
Old 15 Oct 2019, 12:09 pm
First of all, pop rivits not a good choice. Will pop back through. But if you have no choice.
In your particular case. Looks like you got the metal clean on the out side. But the reverse side looks like what you removed. It would be helpful if you could get some of those treatments in behind to slow as much as possible. Then coat the bare metal with it as well. Then instead if call, use Bondoglass. Use it just like regular bondo. It us harder and doesn't absorb moisture. Smith and prime and paint. This will last as good as cut and weld. Why you ask. When you weld a patch in you burn the metal on both sides. If you can't get to it to clean and prime, it's just going to rust again. Plus you will have to pain beyond the gutter because of the heat burning the paint. As you have it. You should be able to keep you work below the top edge.
By the way. Are you close to the ocean. Because I have not seen a cruiser rust there before. Cars around salt air rust in higher areas like yours has. Just curious.
Old 12 May 2022, 12:31 am
Attachment 31212
Attachment 31213
Attachment 31214
Ok we will give that a try for the T100 project.
Excessive oil in spark plug cavity. Rumble Tech & Performance Forum 19 02 Jul 2018 04:09 pm
2004 Platinum with moon roof. 64K. Parts or Repair blownhead Classifieds: For Sale/Trade 5 12 Sep 2015 10:36 pm
Wrap versus Paint for roof paint repair? PGBCruiser The Detail Shop 18 14 Jul 2015 10:06 pm
Sun Roof Repair JoeX General PT Cruiser Discussions 3 03 May 2014 09:50 am
Water in the fuel door cavity piledriver General PT Cruiser Discussions 5 13 Feb 2011 01:32 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
