How to clean carpet
Old 22 Aug 2004, 04:55 pm
Default How to clean carpet
If you have dirty carpet, (like in this pic) the only effective way to clean it is with an extractor. WARNING! Don't go to a detail shop that uses a shop vac to clean carpet. Shop vacs are NOT strong enough to suck up the chemicals used to clean carpet, the result is you will have strong surfactants imbedded in the carpet which will loosen the glue and give mold a prime area to ferment. Here is a tip, if you rent steam machines on occassion to clean your carpet in the home, use the stair attachment in your car, that is an extractor. These machines will suck up chemicals used to clean carpet effectively without leaving behind solution in the fibers.
How Often do you Clean your K&N CHROMEDCRUISER General PT Cruiser Discussions 5 10 Jun 2004 05:59 pm
Carpet color blending turbomangt The Detail Shop 2 10 Jun 2004 04:12 pm
best way to clean rims tdellis The Detail Shop 8 14 Mar 2004 09:08 pm
whats the best to clean the stock gt chrome wheels insane1 The Detail Shop 8 27 Feb 2004 12:32 am
Carpet Cut links Interior Accessories Forum 3 21 Jul 2003 01:40 pm
