PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   The Detail Shop (http://www.ptcruiserlinks.com/forum/detail-shop/)
-   -   Claying instructions>Print (http://www.ptcruiserlinks.com/forum/detail-shop/7538-claying-instructions-print.html)
turbomangt 30 Sep 2004 11:21 pm
Claying is a process that is new to the world of automotive detailing and has found enthusiastic acceptance. It's not hard to understand why, as its resume reads like a miracle cure, and after reading it you may think that it's too good to be true. But claying delivers.
The clay we are talking about is similar to the toy "Play-doh" that kids enjoy although a special type is required for car detailing. It performs it's function by removing the contaminants from the surface of the paint. It works by virtue of its flexibility as it easily forms the exact contour of the surface it is in contact with. What it does for a painted surface is similar to the function of polish, but unlike polish, clay is not an abrasive. This is an advantage for the beginning or casual detailer, as no harm can be done to the paint. Claying also does not remove wax, so unlike polish, there is no need to reapply it after an application. It works on surfaces that might not be appropriate for polish, such as glass, brightwork and trim items. Claying is also relatively quick and easy when compared to a polish job. Clearly a winning situation all around!
How to Clay
To work with clay you will need a lubricant like my spray and shine. "Quick Detailer" spray also works. Claying is done after the car is washed, but before it is waxed, assuming that you are planning on a wax job. To use the clay, apply some of the clay lubricant to the area you are going to work on, which shouldn't be larger than about 2' x 2'. Then glide (in other words, use only minimal pressure) the clay over the surface. If the lubricant is working, the effort to move the clay over the surface will be next to nothing; you are really guiding its movement more than anything else. A lot depends on how much the clay has to pick up.
As you progress, you'll note that the clay bar gets thinner. You'll then have to rework the bar so that it is thick again by kneading it. Some detailers like to just fold it over, the reasoning is that it will have a cleaner surface. You'll get a feel for how it is working by the way it glides over the paint surface. This "feel" will also tell you when the clay bar is losing its effectiveness (it's resistance increases) and needs to be replaced. When you are finished with a section, dry it using the same towels you use after you wash the car. It's a good idea to rinse the entire car with a hose after you are finished with the claying task. When you are finished, do the "baggie test" The results will be easily felt.
Claying is an odd process. If you haven't tried it, it can be difficult to understand as it doesn't seem to conform to most of what we know about car detailing. If this is your thinking, we encourage you to give it a try. It really is easy! Many amateur detailers are a bit wary of the concept but after they try it, they are sold big time.
A clay bar is good for about four to five treatments. This depends on factors such as the size of the vehicles and how dirty they are. One important note: if you ever drop a clay bar, you MUST throw it away. The potential for causing scratches from material it picks up is just too great. If you intend to reuse the clay bar, store it in a box or baggie to keep it clean. Gary
quicksilverdon 01 Oct 2004 08:05 am
Want to agree with Gary 100%. I learned about claying on another PT Forum, gave it a try, and continue to be amazed. Lastest success - got my son a used car that had "hazed" headlights - not glass. Applied claybar, and a great improvement. A second application improved things further.
Keep the bar moist, don't rub too hard, and when it glides freely, you're done. [|)]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
